Bcole
Mar 04, 2017Aspirant
Bug genie 3.1.12 app will not screen rotate to landscape
The genie 3.1.12 android will not screen rotate from portrait to landscape
DexterJB
Mar 07, 2017NETGEAR Moderator
Hi all,
The bugs have been reported and engineering is already aware. Please try uninstalling and re-installing the app to check if some issues will be resolved. Also, please keep an eye on updates for the app for the fixes.
Dexter
Community Team
- BcoleMar 07, 2017Aspirant
Thank you Dexter.
By chance do you know if I will lose my device names and device type setting if I uninstall and Reinstall?
Second is there a release notes or a way to subscribe to a defect so when a correction is released people can be notified or a way to scan through a defects listing based on app version and platform. Hopefully one or both of those might reduce bug repostings.
Thank you,
Billy
- DexterJBMar 08, 2017NETGEAR Moderator
Hi Bcole,
Yes, you will lose the custom device names.
Yes, release notes are usually indicated on the app description portion on the Playstore/Appstore.
Dexter
Community Team
- BcoleMar 08, 2017Aspirant
Tried to uninstall and reinstall on my s3 and that did not fix the screen rotation issue.
