schumaku
Apr 15, 2019Guru - Experienced User
BUG REPORT: Speed Test Information Home Screen Wrong, Speed Test on Router QoS, Localisation, (c)...
Nightawk App, v2.3.1.568 Google Pixel 2, Andoroid 9, up2date
Management Summary: Careless design, poor programming, lack of QA.
Issue A: On the Nighthawk App "Home" view, the (new added)...
schumaku
Issue E: Device Name Configured Not Reflected in App - the App does continue to show a hard coded model number instead. In this example, the device name is R9000-1:
- schumakuApr 16, 2019Guru - Experienced User
Issue F: Attached Device List massive Differences from the Web UI - here 4 vs. 9:
R9000, v1.0.4.28:
Issue G: Despite any promises, no Network Map at all (of course, we expect a FULL network map with ALL (see above...) Attached Devices (not just router and some mesh extenders):- schumakuApr 16, 2019Guru - Experienced User
Issue H: admin (local device) password restrictions - to strict. Password which are working for the Genie Web login, wich used to work in the Genie App, no longer work in the Nigthhawk App, like these ( - _ # ? ....). Login does simply fail, no real user guidance.
Issue I: [My]Netgear Account login - possible password limitations. We see more and more reports, but lack of details for now. The Nighthawk App just hangs, and does not continue from the SSO Login.
Issue K: There ar no mbps or Mbps (inconsitently used, and no standard) - use SI units only. Mb/s or Mbit/s (no lowercase m ... that's mili ... no uppercase B unless you talk of Bytes..
- JlacaraMay 02, 2020AspirantUpgraded to the new app. Now it doesn’t show any devices.
- justCASep 11, 2020Aspirant
iOS Nighthawk App: 2.6.2.12
Firmware Version: 1.3.2.124
Model: R7000P
I'm having tons of issues with the Nighthawk IOS app (current version iOS iPhone X).
For example, error when clicking devices 'Sorry, the action was failed. Please try again.'
Checking for New Firmware --- 'Router Not Found'
Bunch of other issues... is this app still supported? What's going on?
