SSWaltersII
Apr 05, 2020Tutor
C7000v2 WiFiCableModemRouter can't access Remote Management via the Netgear Genie App.
C7000v2 WiFiCableModemRouter can't access Remote Management via the Netgear Genie App although I have enabled http and https for Remote Management in Settings.
Christian_R
Apr 08, 2020NETGEAR Employee Retired
Hello SSWaltersII,
Please refer to the article linked below to enable remote management through the web admin.
http://www.downloads.netgear.com/files/GDC/C7000v2/C7000v2_UM_EN.pdf
Christian
SSWaltersII
Apr 08, 2020Tutor
Thanks, Christian. I'm well aware and already familiar with the WEB remote managemnt.
This is why my question was specifically re the "App".
With that said...can you provide an official list of Netgear Wi-Fi Cable Modem Routers - if any - that can be remotely managed via either the Netgear Genie App or Nighthawk App?
Besides the above, I think the information on the Netgear website is, at best, misleading when it touts remote management and the Genie app in the same context - for devices that they know aren't compatible.
Best Regards,
SSWaltersII
- michaelkenwardApr 09, 2020Guru - Experienced User
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
- SSWaltersIIApr 09, 2020Tutor
Thanks, Michael, but both lists address management via the apps - not remote management via the app.
:smileysad:
It amounts to the same thing. Find the app that supports your hardware. Set up remote management on that hardware and then throw the app at it. I do this all the time.
