SSWaltersII
Apr 05, 2020Tutor
C7000v2 WiFiCableModemRouter can't access Remote Management via the Netgear Genie App.
C7000v2 WiFiCableModemRouter can't access Remote Management via the Netgear Genie App although I have enabled http and https for Remote Management in Settings.
michaelkenward
Apr 14, 2020Guru - Experienced User
Does Remote Management appear on the Nighhawk App?
Remote Management
SSWaltersII
Apr 14, 2020Tutor
Please see attached pdf.
"REMOTE MANAGEMENT" shows up in purple during app load. If I click on it, it takes me to the screen shot labeled "End Result".
Otherwise, if I wait until the app loads (pic #2), click on the Home icon in the upper left, I get the menu (pic #3), it takes me to the screen shot labeled "End Result".
Cheers!
- michaelkenwardApr 15, 2020Guru - Experienced User
That is remote management.
- SSWaltersIIApr 15, 2020Tutor
Huh?! I know what Remote Management is. My OP question was why is it not working for my c7000v2?
- michaelkenwardApr 16, 2020Guru - Experienced User
I don't understand those images.
Three incomplete screen shots piled into one PDF file do not make for clear reading.
The second one seems to who that you are into remote management.
Even on a local network, connected to the modem/router's wifi, you should still be able to connect through Remote Management. This goes in and out through the Cloud service.
Have you actually tried this away from your own wifi network? Or are all your experiments connected to your own wifi?
