DC01
Jun 30, 2020Aspirant
C7800 MODEM/ROUTER
How do I monitor my C7800 Modem/Router remotely? I recently upgraded from the R7000 and could use the Neatgear Nighthawk app to monitor and test speeds. Where may I do that with this current model? ...
michaelkenward
Jun 30, 2020Guru - Experienced User
The C7800 is a modem/router the R7000 is a router. Not all modem/routers can support the Nighthawk app. (It takes a firmware update, and that is not possible for many cable modems.)
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Look at those closely and you will see that, in its inimitable style, Netgear doesn't mention the C7800 in either. However, the manual for the device refers to the Netgear app.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Read up on Remote Management.
