kcb3653
Sep 03, 2020Follower
C7800 Router Modem Combo using App on iPhone/iPad
Does the C7800 Router Modem combo not work with the Nighthawk App on iPhone ?
michaelkenward
Sep 05, 2020Guru - Experienced User
Have you tried it?
Seems not
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
You could try the Netgear genie app:
genie Landing Page | Apps | Discover | Home | NETGEAR
You may have to dismiss an annoying pop-up that tries to push The Nighthawk app down your throat.
