mikegriffiths
Jan 06, 2021Initiate
Can’t connect to Netgear router app after enabling VPN
I have a Netgear AC1900 (R7000) wifi router running on my Mac home network and recently enabled it to support VPN using ExpressVPN. I can connect to the router settings via wifi using the Express VPN ...
Christian_R
Jan 13, 2021NETGEAR Employee Retired
Hello mikegriffiths,
May you reinstall the Nighthawk app and let us know what app version is installed (please also specify if it's iOS or Android).
Thanks,
Christian
- mikegriffithsJan 13, 2021Initiate
Hi Christian,
Thanks for the reply. I did reinstall the Nighthawk app but it did not solve the connection problem. The app version is 2.7.6.3 and it is for the iOS platform. Any suggestions to address the problem are very welcome.Mike- Christian_RJan 14, 2021NETGEAR Employee Retired
Hi Mike,
Thanks for the info. I have sent you a private message.Christian
- jasonmrazMay 02, 2021Initiate
Hi all,
Are you able to post the solution here or message me. I am facing the same problem and would like to be able to access the nighthawk app to create a guest network while maintaining my VPN.
