mikegriffiths
Jan 06, 2021Initiate
Can’t connect to Netgear router app after enabling VPN
I have a Netgear AC1900 (R7000) wifi router running on my Mac home network and recently enabled it to support VPN using ExpressVPN. I can connect to the router settings via wifi using the Express VPN ...
Christian_R
Jan 14, 2021NETGEAR Employee Retired
Hi Mike,
Thanks for the info. I have sent you a private message.
Christian
jasonmraz
May 02, 2021Initiate
Hi all,
Are you able to post the solution here or message me. I am facing the same problem and would like to be able to access the nighthawk app to create a guest network while maintaining my VPN.
