Fharmuth's avatar
Fharmuth
Follower
Sep 19, 2022
Can’t connect to new Spectrum modem
I had Spectrum service for 6 years…moved to new home & kept Spectrum service but they gave me a new modem. I kept my Nighthawk R7000p wireless router but I cant’t get it to connect to new Spectrum router. I tried the app but it cant find router. I get spectrum internet directly to my pc via ethernet but when i take the snae connection & plug it into Nighthawk it wont connect. Amber internet light. Spectrum support says its a nighthawk issue 😕 how can i connect? Tia..
1 Reply
  • plemans's avatar
    What modem/gateway are you using from spectrum?
    You put you're connecting the R7000P to a router, what router is that?
    Reason I ask is if you're using 2x routers, it causes a double nat.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
