jtstarr17
Apr 30, 2020Aspirant
Can’t get app to connect to router
I got a new phone and downloaded the NETGEAR app but it can’t connect to the router. So I can’t set up the app to work? I think it is trying to connect to the default network name and password instead...
michaelkenward
May 02, 2020Guru - Experienced User
jtstarr17 wrote:
I got a new phone and downloaded the NETGEAR app ....
Which app?
Nighthawk? Netgear genie?
- jtstarr17May 04, 2020Aspirant
"NETGEAR Nighthawk - WiFi App"
- michaelkenwardMay 04, 2020Guru - Experienced User
plemans asked about the modem. You replied
"the router plugged into the wall."
Unfortunately, that is ambiguous. It doesn't tell us how the internet gets to you.
Is this a fibre optic service with an "ONT" socket on the wall? Or is it, for example, an apartment with an Ethernet service?
michaelkenward wrote:plemansasked about the modem. You replied
Sorry, I don't know what "ONT" is. We have fiber internet hooked up to our house and just have to plug into the port on the wall to connect. I have the router plugged in directly to the internet port on the wall and run everything else off that. Everything else connects just fine, exept when I try to set up the app. It asks to join the network, but shows the default network name that's on the sticker on the router then it says it can't connect to my router. It doesn't give me an option to change which network it is trying to join or the password it is trying to use. I'm guessing it is trying to connect with the default factory network name and password, but I changed those after originally setting up the app on my old phone.
