Nt301Hwk98
Dec 10, 2022Aspirant
Can’t log out from Nighthawk app
I am unable to log out from the mobile app. I logged into the app, completed what I needed to do. When I went to log out, there was no “logout” option. I closed & re-opened the app, and found that I ...
michaelkenward
Dec 12, 2022Guru - Experienced User
Which bit are you trying to logout from?
In the Android version you have to back out using the on screen navigation. It will then ask me to conform that I want to log out.
The app is designed to remember your credentials and log back in when you start the app.
Has the behaviour of the iOS app changed since you started using it.
- Nt301Hwk98Dec 13, 2022Aspirant
I've had the app since I bought the router. I have kept up with updates.
The behavior of the iOS app didn't occur until the day I posted the problem here.
I'm just waiting for customer support to reply with a solution.
- michaelkenwardDec 13, 2022Guru - Experienced User
Have you asked them? They aren't likely to respond here.
You should know that this community is essentially a user-to-user venue to talk about technical issues, with some input from a small band of Netgear techies.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
I went through the app store, looked up the app, and listed there was an e-mail address to contact Netgear if there were any app issues. That is where I sent my issue to, for a response.
