Nt301Hwk98
Dec 10, 2022Aspirant
Can’t log out from Nighthawk app
I am unable to log out from the mobile app. I logged into the app, completed what I needed to do. When I went to log out, there was no “logout” option. I closed & re-opened the app, and found that I ...
michaelkenward
Dec 13, 2022Guru - Experienced User
Nt301Hwk98 wrote:
UPDATE: My technical support contract ended. In order for me to get technical support, I would have to purchase another contract.
Who did you contact and how did you find them?
I ask that because we have had too many reports here of people being conned by crooks who buy searct results on Google.
They then try to presuade people to give them access to their PCs and have been known to do serious damage.
Until then, I guess for security purposes, I'll just uninstall the app to log out, and reinstall it when I need to log back in when I need to do something with the router.
As I said, your experience does not match mine. There simply is no log out option in the Android app. It is a part of the Android system.
It also logs in automatically when I start the app. Again, that how Android works.
As to doing things on the router. I usually go for the browser graphical user interface (GUI).
Nt301Hwk98
Dec 14, 2022Aspirant
I found the contact e-mail info from the Nighthawk app in the App store.
In regards to contacting Netgear support, I called their customer support line via their website.
