Elms's avatar
Elms
Follower
Apr 24, 2017
Can I disable parental control directly thru routerlogin because genie has an error on opendns?
Can i disable parental control if i log directly to the router using routerlogin?  I always get an error when using Genie.  I need to disable parental control to be able to update my DNS to fix another issue, access to some sites.
Really hope to hear from the community soonest.  Thanks,
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which router is this? You may have given the forum this information, but it has not passed it on to the rest of us.
