bark's avatar
bark
Follower
Apr 22, 2016
Can I manage Parental Controls for devices via the Network Map?
I have the R6400 model and would like to centrally manage access to all devices?  i.e., the hours of access for devices on router?
Can this be done?  OR do I need to install genie app on each device and apply Bypass account?
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi @bark,
    Yes, you can manage the Parental Controls filtering level for each of the connected device on the network through the Network Map of the the NETGEAR Genie app. However, you should have the NETGEAR Genie app/program installed on the devices if you want to use the bypass account method.
    Dexter
    Community Team
