Rich1948
Jun 13, 2016Aspirant
Can I use my WNR3500L v2 as anetwork switch??
 I had to get a Cox Cable modium (a newer NetGear C6300BD) and it is also a Router and WiFi unit, I am told I cannot run two routers on one system so had to disconnect me Netgear WNR3500L v2.     BUT ...
Rich1948
Thanks.
Do I advoid using the Internet plug of can it be the main input and thus giving four switches??
Rich
Rich1948
Darn no spell check and no editing...
Do I advoid using the Internet plug OR can it be the main input and thus giving four switches??
OR do I need to leave it unpluged??
Rich
- TheEtherJun 13, 2016GuruSome routers have a built-in AP Mode setting. I don't think the WNR3500L has this setting. If it does, then skip steps 1-3 that I provided and use the Internet plug. If it doesn't have an AP mode setting, then you must leave the Internet plug disconnected.
