Retired_Member
Sep 28, 2021Can my wifi admin see every single website i went on?
Sep 28, 2021Guru - Experienced User
Depending on their skill/knowledge, yes they can.
Its always good to assume the people who's network you're using, can see the sites you're visiting.
- Retired_MemberSep 28, 2021Okay they have no skill as in just regular basic knowledge. Does the app have a log feature? I mean it was one website (not a blocked one) among a bunch of traffic so would they have seen it?
- plemansSep 28, 2021Guru - Experienced User
If nothings been said yes, I wouldn't worry about it.
Or log in and clear the log.
https://kb.netgear.com/24224/How-do-I-view-the-activity-logs-of-my-Nighthawk-router
And if you're that worried about that site, I'd recommend not going back on it.
- Retired_MemberSep 28, 2021I was just visiting for a few days so i cant delete it unfortunately. Im not familiar with netgear at all so from what I understand you have to manually enable logs right? Or like turn on keyboard blocking? Do wifi admins get notified about the website visited
