hillbc
May 23, 2017Aspirant
Can not change admin password on R6220 router. USING V1.1.0.34_1.0.1 Genie software and Windows10.ty
Can not change admin password on R6220 router. Using Genie V1.1.0.34_1.0.1 software on Windows10 hardwired computer. Option to change admin password not shown anywhere. Option not shown on mobile ver...
DexterJB
Jun 08, 2017NETGEAR Moderator
Hi hillbc,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
hillbc
Jun 08, 2017Aspirant
Yes, I used the mobile app and was finally able to get to a screen where I could change the administrative password. I had benn using a desktop computer that did not have wireless capability. It seems that you must use a wireless connection.
Thanks for your help.
Bob
