bigdargon
Mar 23, 2018Tutor
Can not login using NETGEAR Mobile (iOS) application to router
I can not login using NETGEAR Mobile (iOS) application using Google DNS, OpenDNS ... I try to track the application found that access the domain routerlogin.net is transferred to https://www.netgear....
schumaku
Apr 29, 2018Guru - Experienced User
Just curious - Google Public DNS or OpenDNS IPs are configured on the iOS device as a name server? Or on the AirCard?
In either case, the mobile router should be able to capture the DNS traffic and provide the router LAN IP as an A record.
