Tsteele23
Sep 22, 2015Guide
can you set device based parental controls?
Hi, I have a WNDR3800 router. I am trying to make use of the Parental Controls, which only seem to work for the whole router. ie: I am trying to modify per device settings to configure differe...
jlowe73
Feb 11, 2016Aspirant
I have exactly the same issue on an older wndr3700. will this be getting new firmware, or do I buy a new router to access these new features?
I've tried with Windows 10 PC which indicated no errors and Android app. "Failed to set parental controls", but both always revert to default, so obviously device isn't capable.
| Hardware Version | WNDR3700v2 |
| Firmware Version | V1.0.1.14 |
- DexterJBFeb 13, 2016NETGEAR Moderator
Hi @jlowe73,
1. Are all devices affected?
2. Have you tried re-flashing the latest firmware then resetting and reconfiguring the router? If not, you may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
- jlowe73Feb 13, 2016Aspirant
Thanks Dexter,
Are you saying that the WNDR3700v2 DOES SUPPORT individual device settings?
Because, if it does, I will try reflashing the firmware (although I think it is a few years since the firmware release was updated, and I already have this version anyway.)
If it doesn't support it, then re-flashing won't change anything and I think I will have to buy a newer router?
Thanks,
Justin.
- DexterJBFeb 14, 2016NETGEAR Moderator
Hi @jlowe73,
I apologize since the version 2 (v2) does not support that feature since it does not have the Genie UI. I would recommend getting the newer routers instead if you are looking to get the Parental Controls feature.
Dexter
Community Team
