Tsteele23
Sep 22, 2015Guide
can you set device based parental controls?
Hi, I have a WNDR3800 router. I am trying to make use of the Parental Controls, which only seem to work for the whole router. ie: I am trying to modify per device settings to configure differe...
720347
Mar 19, 2016Aspirant
I've been having the same problem as everyone else with a D3600. I've tried rolling back, rolling forwards access from Windows and Android genie apps to no avail. It's been a total waste of time and the router is being returned. I personally feel misled because the box the router came in mentions that it's compatible with the genie app and supports parental controls on a per device basis. The app apparently exposes controls and features that are not hosted on the router which is also misleading.
