Tsteele23
Sep 22, 2015Guide
can you set device based parental controls?
Hi, I have a WNDR3800 router. I am trying to make use of the Parental Controls, which only seem to work for the whole router. ie: I am trying to modify per device settings to configure differe...
DexterJB
Apr 05, 2016NETGEAR Moderator
Hi @Joe2386,
The firmware version of your router indicates that it is an ISP supplied device which means that there are modifications made by the ISP. Some features of the device may end up not working.
Dexter
Community Team
marsol
Aug 15, 2016Aspirant
Hi all,
i have the same problem with my wndr4300, new firmware and genie application.
You have to do the following:
The router firmware is not able to authentificate in that menu to opendns and therefor the router can not receive your decided live parental control settings from that site.
Workaround:
You first have to login to opendns and create bypass accounts for all your network devices you wish to configurate with different LPC settings (as router default).
Then you have to install the genie application at all of these clients and login to genie and life parental control menu with your opendens account. Then choose/authentificate the created bypass account.
Then you can disable, with the taskbar icon of genie, to start genie when windows comes up or even you can uninstall genie at these clients.
The depended information stays at the routers ROM, even you restart your router, but not when you reset it.
Tip:
If you change at opendns.com your filters of the bypass accounts, you have to wait 5 minutes and then the filter is operative at the client, without reboot of the client or router
Greetings from germany
Harry
- godly75Nov 22, 2016Aspirant
Same problem here.
Filtering on device level in the network panel does not work (pc version and android app)
WNDR4300 firmware 1.0.2.80
Pitty, because good parental control on a router is important.
Also keyword filtering would be apreciated with the parental control (it's either 1 or the other it seems)
- DexterJBNov 22, 2016NETGEAR Moderator
Hi godly75,
1. Please make sure that the DNS values on the router UI are set to 208.67.222.222 and 208.67.220.220.
2. You can make use of the keyword blocking feature via the router since OpenDNS does not support this. You can check the link below.
http://kb.netgear.com/app/answers/detail/a_id/24053
Dexter
Community Team
- Sergii_PuliaievMar 26, 2017Aspirant
Hi,
have exactly the same issue - cannot change the level of filtering per device using the Network Map.
Router model: C6300
Hardware Version V3.0
Firmware Version V1.02.21Genie Version on Mac: 2.4.22
Genie Version on Android: 3.1.12
On Android device: "Setting failed."
On MAC book: no error is show, however it is still stated "Default level on router" after refresh the Network Map.
