Tsteele23
Sep 22, 2015Guide
can you set device based parental controls?
Hi, I have a WNDR3800 router. I am trying to make use of the Parental Controls, which only seem to work for the whole router. ie: I am trying to modify per device settings to configure differe...
DexterJB
Sep 22, 2015NETGEAR Moderator
Hi Tsteele23,
You have followed the correct steps in completing the setup that you want. I recommend performing a firmware re-flash then reset and reconfigure the router. You may refer to the links below for the steps:
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Once you have successfully reconfigured the router, please try uninstalling and re-installing the NETGEAR Genie applications on all devices and check if it works.
Dexter
Community Team
- Tsteele23Sep 27, 2015Guide
Dexter,
I've reflashed and reconfigured, and still stuck with the same problems. Trying to changing the level of parental control per device is not saving.
I installed the Genie app on my tablet, and it gives me an error after clicking Apply : "Failed to set Parental Controls Filtering"
Any ideas?
Tim
- DexterJBSep 28, 2015NETGEAR Moderator
Hi Tsteele23,
I will need the following information for me to provide you with a better recommendation:
1. May I know what is the firmware version of the router?
2. Are you getting the same error on all devices?
3. Have you tried uninstalling and re-installing the app on the devices?
Dexter
Community Team
- Tsteele23Sep 28, 2015Guide
Hi Dexter,
1. May I know what is the firmware version of the router? 1.0.0.48 (latest available)
2. Are you getting the same error on all devices? to date I have installed Genie on my MaxOS & Android tablet (4.4.4), & Windows7 PC. All of them I couldn't set the filtering level per device. However just now have installed Genie on an ipad mini, and I can change the filtering level on each device. It responds with "Set Sucessfully"
I have one more MacOS I can try a new install on, and one more Windows7 PC. At this point in time, it appears this functionality is only working on an ipad.
3. Have you tried uninstalling and re-installing the app on the devices? I haven't yet tried uninstalling & reinstalling, but I will try this now, along with new installs on the other devices I mentioned in 2.
I'll update you later.
Tim
