Dyathias
Nov 13, 2016Tutor
Cannot connect to OpenDNS account after firmware update
I already made a post on OpenDNS and submitted a ticket to their support team. They told me open a ticket through netgear. I just wanted to know if anybody else is having this problem. https://su...
- Jan 05, 2017
Hi jdfet,
1. What is the model number and firmware version of the router?
2. What version of NETGEAR Genie do you have installed?
3. Are you able to login to your OpenDNS account via https://netgear.opendns.com/sign_in.php?
4. Are you using an OpenDNS account or did you register using the NETGEAR Genie?
Here are a few steps you can try:
1. Login using a different device (Android, iOS, another computer).
2. Reset the router.
3. Register a new account via the NETGEAR Genie.
Dexrter
Community Team
DexterJB
Nov 18, 2016NETGEAR Moderator
Hi Dyathias,
1. LPC will use the OpenDNS DNS values which are 208.67.222.222 and 208.67.220.220. This is normal since the filtering will be done from their end.
2. Please try using the previous version of NETGEAR Genie for Windows using the download link below.
http://files.netgear-support.com/go/?a=d&i=dindu7kEQV
Dexter
Community Team
Dyathias
Nov 18, 2016Tutor
Hello Dexter!
I fixed the DNS problems, I just needed to change the IP values. I'm still having problems with the netgear genie app. I tried the version you linked to, but it still didn't work. I even tried upgraded the app from the downgraded version--no luck. It just gives me, "There was an error signing in, please make sure you're connected to the Internet and try again.". I have tried them on all the desktops we have in the house.
Thanks!
- jdfetJan 02, 2017Aspirant
Having same issue. Was this resolved?
- DexterJBJan 05, 2017NETGEAR Moderator
Hi jdfet,
Dexrter
Community Team
