NickTaylorATX
Jul 30, 2022Initiate
Cannot Delete Device
Hello. I have a device on my device manager list within my Netgear Nighthawk app that I am unable to identify. I want to delete it, but there's no option to "Delete Device". This is the only devic...
Dec 01, 2022Guru - Experienced User
Any progress on this?
There is newer FW available:
What mobile platform are you using?
What version of the App are you using?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
