msbusby
Nov 23, 2022Tutor
Cannot enable Anywhere Access on Nighthawk App 2.21.0.2590
Cannot enable Anywhere Access on Nighthawk App, have latest firmware v1.0.11.112. Recently had to do a factory reset, but access anywhere will not turn on on App. I also re-downloaded the Nighthawk a...
Nov 23, 2022Guru - Experienced User
Have you uninstalled then re-installed the app?
Try a different device to compare?
msbusby
Nov 23, 2022Tutor
I have tried on 3 android devices (2 phones/1 tablet), two of which I downloaded the app from the play store today. They all are the same. I can connect locally with some issues (even though wifi on and device connected the Nighthawk app says it can't find the router, but then after a second or third try it will connect). The access anywhere was working fine until a few days ago, when something happen with the router, and when I re-booted it defaulted to the Netgear Wifi network(not what I had named it), as an open network. I did a factory reset and renamed to the original personal wifi network name using the Nighthawk App.
ISP = WOW - 1GB/ Modem is Arris Touchstone CM8200
- FURRYe38Nov 23, 2022Guru - Experienced User
Ok, I recommend submitting a bug report on this by this method;
Your not the only one and I've passed this on to NG as well.
