msbusby
Nov 23, 2022Tutor
Cannot enable Anywhere Access on Nighthawk App 2.21.0.2590
Cannot enable Anywhere Access on Nighthawk App, have latest firmware v1.0.11.112. Recently had to do a factory reset, but access anywhere will not turn on on App. I also re-downloaded the Nighthawk a...
msbusby
Nov 23, 2022Tutor
I have tried on 3 android devices (2 phones/1 tablet), two of which I downloaded the app from the play store today. They all are the same. I can connect locally with some issues (even though wifi on and device connected the Nighthawk app says it can't find the router, but then after a second or third try it will connect). The access anywhere was working fine until a few days ago, when something happen with the router, and when I re-booted it defaulted to the Netgear Wifi network(not what I had named it), as an open network. I did a factory reset and renamed to the original personal wifi network name using the Nighthawk App.
ISP = WOW - 1GB/ Modem is Arris Touchstone CM8200
Nov 23, 2022Guru - Experienced User
Ok, I recommend submitting a bug report on this by this method;
Your not the only one and I've passed this on to NG as well.
- msbusbyDec 13, 2022Tutor
Have submitted. No response, and not working.
- FURRYe38Dec 13, 2022Guru - Experienced User
Does this work?
FYI about Apple devices:
- MGogulapatiDec 19, 2022Tutor
msbusby Have you tried downgrading the router firmware to the prior version?
In my case, i had exact similar experiences as you on my netgear RAX48 router with the latest firmware update. Couple of days ago, i've downgraded the router to the prior version of the firmware and things are back to normal with Anywhere Access from my Andriod Nighthawk app (latest version).
MG,RAX48 - V1.0.10.110_2.0.75
Nighthawk - V2.21.1.2602
- TasomDec 13, 2022AspirantI'm having the same issue on an MR80,have submitted bug report.
