msbusby
Nov 23, 2022Tutor
Cannot enable Anywhere Access on Nighthawk App 2.21.0.2590
Cannot enable Anywhere Access on Nighthawk App, have latest firmware v1.0.11.112. Recently had to do a factory reset, but access anywhere will not turn on on App. I also re-downloaded the Nighthawk a...
msbusby
Dec 13, 2022Tutor
Have submitted. No response, and not working.
MGogulapati
Dec 19, 2022Tutor
msbusby Have you tried downgrading the router firmware to the prior version?
In my case, i had exact similar experiences as you on my netgear RAX48 router with the latest firmware update. Couple of days ago, i've downgraded the router to the prior version of the firmware and things are back to normal with Anywhere Access from my Andriod Nighthawk app (latest version).
MG,
RAX48 - V1.0.10.110_2.0.75
Nighthawk - V2.21.1.2602
