ltaama
Nov 18, 2022Tutor
Cannot get Nighthawk to work with new phone
I just attempted to opened my Nighthawk App on a new phone. My app and Netgear account were using a very old email address so I went online and changed my email address to my new one. I am able to lo...
- Nov 20, 2022
Please refer to my response in the step by step process above (steps 3, 4, and 5). This issue is verifying my identify, I need to add the verification code sent to my old email address (which I do not have access anymore). I have not made any changes to the router. I only replaced my phone. The error is occurring after entering my login credentials (to mynetgear.com).
Answers to your questions.
- I have uninstalled and reinstalled the Nighthawk app multiple times with the same result. Firmware version: v2.21.0.2590.
- I can successfully login mynetgear (this is were I am now). I connect via a web browser.
I have attached a screenshot showing sequence of events.
Thanks for all your replies.
ltaama
Nov 19, 2022Tutor
What happened when you tried it?
Upon login the app says "We don't recognize this device.
Opened it to do what? Which Netgear device are you using?
Using Nighthawk app to connect to my Netgear Nighthawk router (RAX50).
Which Netgear account was this? MyNetgear? This community? Anywhere Access?
I can connect to the router using the ip address from a browser. It only fails when attempting to connect to the router using Nighthawk app on the phone.
Take us through the steps you use and what happens.
Step by step process:
1. Open Nighthawk app on the Android phone (Samsung Galaxy S22+)
2. Option to log in. Sign into existing account.
3. Enter my user id and password.
Received error: "We don't recognizer this device. Unable to login. We can't verify your account. Please try again or try another method to login by other available options."
4. Select "Try Another Verification Method"
5. Option to select email address. Note: The only email address listed is my old email that I no longer have access. It is not the email address I changed on the Netgear portal. As I stated, I can use my new email address and password to sign in to my Netgear account from a browser. Appears changing the email address from the portal does not change it all over Netgear.
Hope this provides some clarity. Thanks for your replies.
michaelkenward
Nov 20, 2022Guru - Experienced User
This is using a local wifi connection. It is completely different from the app.
Can you login to mynetgear.com?
The app depends on having Anywhere Access set up on the router.
When you ;login, it will establish a connection to the router via the Netgear cloud system that hosts Anywhere Access.
If you are connected to the wifi, you then get a choice of Local Connection or Anywhere Access.
You said earlier:
Where did you do that?
mynetgear.com?
Which firmware version?
- ltaamaNov 20, 2022Tutor
Thanks for all your replies.- ltaamaNov 20, 2022Tutor
Thanks for all your help. I was able to get the Nighthawk app connected to my router. I was overlooking the option to "Login with one-time password". Once I logged in using the one-time password, I was able to connect to the router. Once I was logged in, I enter my credentials for the router. I still would like to know how to get the old email address removed from my netgear account. Thanks again for your help.
- michaelkenwardNov 21, 2022Guru - Experienced User
In MyNetgear:
then
Not necessarily. Where you are now is the Netgear Community.
https://community.netgear.com/
Mynetgear is
That is where you register the devices you own, among other things. It is also the way onto the app and Anywhere Access.
As I said earlier, Netgear has played around with these things over the years. More recently, it has tied MyNetgear credentials – passport and username – to both places.
In my case, MyNetgear and Community are completely different, with different email addresses.
That is why I have been asking questions about where you had changed the password.
These questions may have seemed meaningless to you, but you said you had an old email address, so there was a possibility that you had changed the email address in the community but not on MyNetgear. (And vice versa.)
