stocks33's avatar
stocks33
cannot log in to my router...Plz HELP
i used to be able to log into my router through the genie now it wont .  this is the error message I get "NETGEAR rounter is not found or is not supported."  plz help, why is this so hard.? a dissati...
  • stocks33's avatar
    stocks33
    Jul 26, 2016
    thanx i fixed it by resetting the router.  thanx
