Linypenny16
Apr 23, 2017Tutor
Cannot Login to Genie App
No matter what I try, I cannot login to the Netgear Genie app either on my phone or on the computer. I always get an error message. This has been occurring since the first update a few months ago. I j...
Linypenny16
Apr 23, 2017Tutor
"The network connection is busy, try again later. Of it fails constantly, power cycle your Netgear router and try again."
I've restarted the router and uninstalled and reinstalled the all but continue to get that message.
DexterJB
May 02, 2017NETGEAR Moderator
Hi all,
We are currently investigating the issue. We will provide an update once available.
Dexter
Community Team
- michaelkenwardMay 03, 2017Guru - Experienced User
When I changed my PC's LAN hardware – the motherboard port died – the desktop genie would not log in.
The only way to gain access is to Enter router's IP address manually.
I then have to replace the address in the genie – 54.69.75.161 – with the local address.
The login process then seems to stall. Eventually, after clicking around with various tabs, it lands in the right place.
Oh, the browser also refuses to use the usual access addresses and I have to use the IP address.
I don't know if this is a genie issue or a local thing.
- TechsnifferJun 16, 2017Aspirant
Hi all,
Dexter
Community Team
Can we PLEASE get an answer on this issue? I've seen dozens of this same post adn everytime its the same canned response and questions. Seriously Netgear if you dont have a programmer that can resolve this issue in 6+ months then maybe it's time to hire one that can.
The old PC version worked great, the new one is garbage. The old Android and iOS apps worked fine, the new ones are garbage.
Stop quizzing the users when we ask questions as if you've never heard of these problems before, you know there is a problem you cant type in Netgear Genie without seeing 20 of these same posts, fix your trash and quick.. or many of us will gladly purchase a brand that can make a router and software that isnt total trash.
- DexterJBJun 23, 2017NETGEAR Moderator
Hi nytiger73,
1. What is the model number and firmware version of your device?
2. Please make sure you do a factory reset after updating the firmware.
Dexter
Community Team
- EEWdadJun 23, 2017Aspirant
I'm using the latest firmware update for my R8000; I hate to have to do a factory reset -- essentially wiping out out all my network names, passwords and other settings -- especially if that is not assured to resolve the issue. Are you suggesting a factory reset is the solution?
