NYu
Apr 19, 2025Initiate
Cannot login to Netgear modem/router C7000v2
I have a Netgear C7000v2 cable modem/router. Been using it for years and it's still working. However I can't log into the router either through the Nighthawk App on iPhone, nor through 192.168.0.1, n...
- Apr 21, 2025
Try a factory reset and setup from scratch with a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
NYu
May 14, 2025Initiate
Thank you. That worked .
May 15, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
