Jazzfish_77
Nov 06, 2017Aspirant
Cannot login with NetGenie
I am unable to logon to Parental Controls through NetGenie. I have the router update with firmware V1.0.1.26_1.0.19. I use WIndows 10 and ESET Internet Security 10. When I click on the Parental Contr...
DexterJB
Nov 08, 2017NETGEAR Moderator
Hi Jazzfish_77,
1. Have you tried using another device (Android, iOS, another computer)?
2. Are you able to login to the router using the NETGEAR Genie app (not via the Parental Controls option) to check if the app detects the router?
3. Have you tried temporarily disabling the security software?
Dexter
Community Team
DexterJB
Nov 10, 2017NETGEAR Moderator
Hi Jazzfish_77,
1. Please try using another device and check if the issue persists.
2. Are you logging in to https://netgear.opendns.com/sign_in.php?
Dexter
Community Team
- Jazzfish_77Nov 10, 2017Aspirant
Dexter,
Thanks for your feedback.
I will try to log on through another device when I get a chance. I did log on through the link you provided, which works fine and I can set the parental controls. Unfortunately, they are never pushed out to the router and nothing is blocked.
- DexterJBNov 14, 2017NETGEAR Moderator
- Jazzfish_77Nov 14, 2017Aspirant
Thanks. Unfortunately, nothing works. It is essentially a useless feature.
Even on another device I coudn't log on to the router through Netgenie Parental Controls.
To clarify, I can occasionally (rarely) logon to the router through NetGenie parental controls which brings me to a logon box for my OpenDNS account, but that never works. I can logon to the OpenDNS account through my browser, but setting changes never take effect.
