BBBB
Mar 07, 2020Tutor
Cannot pause device from remote using netgear nighthawk app
For the purpose of pause and unpause/reconnect devices of my kids I use the netgear nighthawk app. Everything was working fine up to about 3 to 4 weeks ago. Now I can pause all except one device (a d...
BBBB
Mar 25, 2020Tutor
Hi, I do have exactly the same issue now on a different router in a different building with the same setup. It is only one device, Desktop PC, connecting over WiFi. Anybody else having similar issue? Solution?
- Christian_RMar 26, 2020NETGEAR Employee Retired
Hi BBBB,
May you provide the model number of your router, the current firmware version it's on along with with the app version you currently have installed.
Thanks,
Christian
- BBBBMar 27, 2020Tutor
Thank you for contacting me. As to not make any typos, I just took a picture containing app version, firmware version and serial no. of R7000. Pls consult attached pic. Thank you.
Mark
- Christian_RMar 30, 2020NETGEAR Employee Retired
Hi Mark,
Thanks for providing that. Does the issue persist when connected locally? You may also try using a different device locally or remote along with toggling the remote management feature on/off again.
Please let me know if any of these suggestions work.
Thanks,
Christian
