dtaft
Nov 15, 2023Aspirant
Cannot rename devices on Nighthawk APP or using mywifiext EAX20
I have devices with no names and no way to edit them. I have done this in the past, but currently I cannot find a way to do this. There is no option to edit, either in the Nighthawk APP or logging in...
michaelkenward
Nov 15, 2023Guru - Experienced User
Is this a reference to names in "Attached devices"?
This is a notoriously flakey are for Netgear devices.Apps don't help because they also have their eccentricities.
One way to name things is to do it in a web browser and the graphical user interface (GUI).
You could also try it on the router that feeds this AP.
You say:
There is no option to edit, either in the Nighthawk APP or logging in with mywifiext.
Have you clicked the icons for the devices?
dtaft
Click the icons....No Icons here on the web login. If you mean the APP, I have clicked on everything I can see.
- dtaftNov 15, 2023Aspirant
App main page... I click the white dot with circles, the named device, the unnamed .... all they do is pull up the devices info, there is no way to edit the device name here. When I am looking at the device info, there is nothing there I can click which pulls up a way to edit it either. I press the dashes, the white doted circle icon, and the .. next to the green dot. None of them do anything.
- michaelkenwardNov 16, 2023Guru - Experienced User
We still don't know where you are looking. I did ask if you were talking about Attached devices.
"Is this a reference to names in "Attached devices"?"
Your screen grab seems to show Access Control.I'm looking at an R7800 in AP mode. I realise that this is different hardware, but Netgear tries to maintain some sort of commonality in the GUI, so I'm hoping that you see the same thing, or something similar. (The manual suggests that it does.)
In the settings
- Attached Devices
(The EAX20 manual also talks about Connected Devices.)
I see this:
Attached Devices
Each of those icons is clickable. Click one and it brings up this:
Edit Device
Do you see something similar?
There are other ways to edit devices, with the "desktop genie" for example. But that's the easiest.
- dtaftNov 16, 2023Aspirant
I was logged in via the web using http://mywifiext/
I logged in, selected settings, and connected devices.
That is the only place I see devices, and as the screen shot showed, some have names but 2 of them say the names are --.
Nowhere is there any icon to click, or any button saying edit, so that I can put names to the devices which just show IP addresses and have device name --
I looked through the manual and I do not see anyplace I could do this. I thought I assigned names for things when I first set this up a year or two ago.
Now on the router, I can see attached devices, and there is a button to click to edit and change names of them.
But I need to be able to do this to the devices on the Extender.
Have you tried changing the settinngs there and seeing if they carry over to the extender?
I have many places where I can change these settings. (Nighthawk App, router GUI, AP GUI and desktop genie) Once fixed on one, they carry over to the others. It would be bothersome to have to change them individually in all of those places.
That's not really "via the web" as I understand it. That is the browser's way into the graphical user interface (GUI). It goes nowhere near "the web". You can even get there without an Internet connection.
