LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
RVG4
Feb 19, 2016Aspirant
DexterJB
Feb 20, 2016NETGEAR Moderator
Hi @RVG4,
The reason why we ask for these information is for us to perform our own test in our lab. This also helps us isolate the issue and provide the right answer or solution at the soonest possible time. We always appreciate your cooperation since not all solutions apply to all users.
Dexter
Community Team
- juicelandFeb 25, 2016Tutor
Hello
We have just created an OpenDNS account which we can login to directly without problem, we have created a 15 digit password which meets OpenDNS requirements.
When we attempt to login via Genie, we get the error "There was an error signing in, please make sure you are connected to the internet and try again".
We are connected to the internet and logged into OpenDNS under the associated account.
1. Are you still trying to register an OpenDNS account or do you already have an existing one? HAVE ONE ALREADY - TRIED 2 SEPARATE ACCOUNTS
2. Have you tried uninstalling and reinstalling the program/app? YES
3. What version of the NETGEAR Genie program do you have installed on the laptop? 2.4.20
4. Are you getting an error message? If yes, what is it? "There was an error signing in, please make sure you are connected to the internet and try again".
5. What is the model number of your device? DGN1000
6. What is the firmware version? V1.1.0.50
Please advise.
Thanks
John
- DexterJBFeb 27, 2016NETGEAR Moderator
Hi @juiceland,
1. Have you tried signing in using other devices (smartphone, tablet, another computer)?
2. Have you tried signing up for a new account through the app/program?
Dexter
Community Team
- juicelandFeb 29, 2016Tutor
Hi Dexter
1. Have you tried signing in using other devices (smartphone, tablet, another computer)? NO
2. Have you tried signing up for a new account through the app/program? YES
Thanks
John
