LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
DexterJB
Mar 12, 2016NETGEAR Moderator
Hi @Zabardast,
1. Have you tried using another device (another computer, Android device)?
2. What version of NETGEAR Genie do you have installed?
3. What error message are you getting?
Dexter
Community Team
Retired_Member
Mar 13, 2016Please see my responses: 1. from my macbook and my ipad 2. Netgear Genie v 2.4.10 3. from NetGear Genie: "Login failed. the router response timed out" BTW Netgear Genie gives same error when I click on Router Settings or ReadyShare. Under Netgear Genie Parental Controls I get the following message: "Checking router firmware We're making sure you have the firmware that supports Live Parental Controls. You don't appear to be connected to the internet. Please connect to the Internet through your NETGEAR router and try again." Let me know how to proceed. Thank you
