LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
DexterJB
Oct 23, 2015NETGEAR Moderator
Hi LorneAv,
This has already been reported and is currently being looked at. I will be sending an inquiry to Engineering and will provide an update on this thread.
Dexter
Community Team
DianaSiordia
Sep 28, 2016Aspirant
I have This problem to, I cannot set up an Account open DNS for parental control, what I can do
- DexterJBOct 03, 2016NETGEAR Moderator
Hi DianaSiordia,
1. What is the model number and firmware version of your device?
2. What is the NETGEAR Genie version that you have installed?
3. Have you tried using another device (smartphone, tablet, another computer)?
Dexter
Community Team
- alisonxgrahamOct 04, 2016Initiate
1. Netgear Router: WNDR3700v3 Firmware: v1.0.0.38_1.0.31
2. Netgear Genie v2.4.26 running on Windows 7 PC (64 bit)
3. Yes - Netgear Genie (v 2.4.24) on ipad 2 (IOS 9.3.5)]
Thanks in advanceAlison
