LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
DianaSiordia
Oct 12, 2016Aspirant
I ready did uninstall it and install it many times and still does not work, what can I do? I really need it
I appreciate your help
Diana
Diana
DexterJB
Oct 18, 2016NETGEAR Moderator
- TonyWilathOct 29, 2016Guide
Hi Dexter
Just letting you know a new firmware version has been released for the D7800 (1.0.1.16). I upgraded my modem/router to this version and tried the parental control login using the Netgear Genie application.
My issue has now been going on for 1.5 months now and I can see others have had this issue for even longer. Netgear replaced my physical modem/router and the issue still persists despite new hardware and multiple firmware versions.
Are your best Netgear Genie developers looking at this issue? I would like to understand what Netgear is doing behind the scenes (i.e. what actions are they taking) given their product is not working as advertised?
Regards
Tony W
- DexterJBOct 31, 2016NETGEAR Moderator
Hi TonyWilath,
We appreciate your patience and especially your cooperation in helping us find a resolution to the issue. We apologize if this has taken longer than usual and for the inconvenience this has caused you and others who are also experiencing the issue. I do not have visibility with regards to the development team. Rest assured, this case is being given attention by the right people and is being addressed.
Dexter
Community Team
- TonyWilathNov 09, 2016Guide
Hi Dexter
Just letting you know that support provided me with the beta Firmare version for me D7800 router (v1.0.1.18-RC2.img). This did not fix my sign in issue to parent control using the Genie application.
I am still waiting on a viable fix and its been close to two months since I logged my support call.
Regards
Tony W
- DexterJBNov 10, 2016NETGEAR Moderator
Hi TonyWilath,
Thank you for providing an update. Please keep us posted if there is a resolution if you are continuing to work with support.
Dexter
Community Team
