LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
Gitzman
Feb 10, 2017Aspirant
SIGH. Unfortunately no, it didn't last more than 6-12 hours. Eventually it fell into a clear pattern where use of LPC would trigger a time-delayed lockout of all wireless clients. To rectify that, I had to disable LPC. And once I did that, debugging was frustrating because the OpenDNS login credentials would be rejected as outlined above.
After spending two days working in a solution, I returned it to the store and bought an Asus RT-AC3100. I got it fully installed and configured, with parental controls, in under an hour and everything has worked fine since then.
