LorneAv
Oct 23, 2015Tutor
cannot sign in to openDNS account to set-up parental controls using NETGEAR Genie
Hi, I am trying to use NETGEAR Genie Parental controls and when I attempt to login to my OpenDNS account, I get the following error message: "There was an error signing, in please make sure you're ...
DexterJB
Oct 23, 2015NETGEAR Moderator
Hi LorneAv,
This has already been reported and is currently being looked at. I will be sending an inquiry to Engineering and will provide an update on this thread.
Dexter
Community Team
- guddootomarOct 24, 2015Aspirant
I have jwnr2010w5 router and the problem is same.
- LorneAvOct 25, 2015Tutor
Thanks, Dexter. Hopefully Netgear engineering team can come up with a solution soon - as you can see from other posts, there seems to be a lot of people having the same problem.
- pharesalOct 25, 2015Initiate
well????? I am same - answers please!
- DexterJBOct 26, 2015NETGEAR Moderator
Hi pharesal, ckelly38237, TCasb7793, jhhansen3, snowedin, guddootomar,
We sincerely apologize for the inconvenience. Engineering is currently working on a fix. In the mean time, you can try using an iOS or MAC OS X device to log in to your OpenDNS account using the NETGEAR Genie for you to setup and manage LPC.
Dexter
Community Team
- ckelly38237Oct 27, 2015Tutor
Tried it from my Mac (Running OSX El Capitan). I get the same error. It acts as if I am not conected to the internet though I am.
- denbo671Dec 27, 2015Aspirant
Is there an update to this? I am unable to sign into opendns through nEtgear genie.
- bill224Apr 03, 2016Tutor
I reviewed all can't see how the problem solved except some would get private emails from "professional". my problem has a bit different because I believed all probelms caused by openDNS that is not part of netgear company's product but other company embeded in netgear such as we bought router WNDR3400.
can't login (router settings, parental controls and ready share) happened after I made a mistake to click parental controls.
finally I got rid of openDNS but still can't login for router settings, parent controls and ready share.
still felt openDNS in charge that speed slow down, frequently got connection failed. even in parental controls shows --you don't appear to be connected to the internet which is ridiculous. shouldn't netgear help me back to normal life? netgear should post a warring openDNS is "other" company products could cause problems and netgear won't be responsible to fix..
Just by accident made a mistake to test netgear "new" function--parental controls then been tortured till router died.
attached one of paper that had same desiring to get rid of openDNS:
I have tried changing the primary and secondary DNS servers to 8.8.8.8 and 8.8.4.4 (Google's public DNS servers) on the router and rebooting it. Ditto on the individual machines. But these don't seem to have changed anything. I presume the ISP is somehow overriding it.
- DexterJBApr 05, 2016NETGEAR Moderator
Hi @bill224,
1. What is the firmware version of the router?
2. What is the version of the NETGEAR Genie program that you have installed?
3. Have you tried logging in using other devices (another computer, smartphone, tablet)?
4. Are you still looking to use the Parental Controls feature of the device?
5. Are you also getting slower speed through the router?
6. Does the connection to the Internet also drop?
Dexter
Community Team
- eeclark71Apr 24, 2016Aspirant
I am having this exact problem. I am trying to set up parental controls and am unable to log in with my correct password and username.
I am needing to set these controls up TODAY.
Any suggestions?
- DexterJBApr 26, 2016NETGEAR Moderator
Hi @eeclark71,
1. What is the model number and firmware version of your device?
2. Do you already have an existing OpenDNS account or are you trying to set it up with the NETGEAR Genie program/app?
Dexter
Community Team
- Retired_MemberApr 26, 2016
I followed these instructions by the tech support team to resolve the issue
1. Power cycle the router
2. Logged in Genie and reset the admin password for the router. Made sure it was all character and numbers
3. Clicked on Parental Control option and followed the instructions..rest of it worked out perfectly.
Hope it helps
Thanks
- DianaSiordiaSep 28, 2016Aspirant
I have This problem to, I cannot set up an Account open DNS for parental control, what I can do
- DexterJBOct 03, 2016NETGEAR Moderator
Hi DianaSiordia,
2. What is the NETGEAR Genie version that you have installed?
3. Have you tried using another device (smartphone, tablet, another computer)?
Dexter
Community Team
- alisonxgrahamOct 04, 2016Initiate
1. Netgear Router: WNDR3700v3 Firmware: v1.0.0.38_1.0.31
2. Netgear Genie v2.4.26 running on Windows 7 PC (64 bit)
3. Yes - Netgear Genie (v 2.4.24) on ipad 2 (IOS 9.3.5)]
Thanks in advanceAlison
- Cassie21Nov 10, 2016Aspirant
Did the engineeers ever fix the problem?. It is 11/2016 and issue remains.
