woodstockmichae
Sep 30, 2023Aspirant
cannot sign into Netgear account using Nighthawk app on my Samsung S23
To use the Nighthawk app I have to first sign onto my Netgear account. However, when I input my user name and password, I get an error message that says "Device not recognized" and will not log me in...
michaelkenward
Oct 01, 2023Guru - Experienced User
woodstockmichae wrote:
To use the Nighthawk app I have to first sign onto my Netgear account. However, when I input my user name and password, I get an error message that says "Device not recognized" and will not log me in. Login Denied
Which username and password are you entering?
That final stage is to enter the username (admin) and password for managing the router.
This is the same details that you use when logging into the browser graphical user interface (GUI) using a wired connection to the router.
woodstockmichae
Oct 01, 2023Aspirant
I am entering my user name and password for Netgear account as the prompt asks, not the username and password for managing the router itself. They are independent of each other
- michaelkenwardOct 01, 2023Guru - Experienced User
I know. That's what I tried to explain.
You need both.
At what stage does it fail?
Can you login to MyNetgear with a browser?
NETGEAR - Common Account Management
- woodstockmichaeOct 03, 2023Aspirant
Yes, I can sign in using browser on laptop and using browser on phone.
The login fails immediately in NightHawk app. As soon as I enter Netgear user name and pw, i get login failed message. "This device not recognized."
- FURRYe38Oct 03, 2023Guru - Experienced User
Be sure to disable any MAC Address randomizers on the mobile device:
Try this as well:
