Peveo's avatar
Peveo
Follower
Oct 12, 2017
cant acces Circle with Disney
Just updated my R700 router and discovered the Circle parental control. Y installed the Circle app on my ipad and then the trouble started. After setting the app up y installed a profile and it went allright. However, when y try to login on the Circle app another time y cant because y need to insert a 4 digit number that was send to my phone. Y think y did put the wrong number because y didnt receive any information on my phone. How can y correct this because now y cant use the Circle possibility on my R7000
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Peveo,
    We recommend contacting support over the phone since it may require some verification from you.
    Dexter
    Community Team
