dapunz
Nov 23, 2022Follower
Can't access app CAX80
I've tried to access the app multiple times and it keeps bringing me back to the login screen.
michaelkenward
Nov 24, 2022Guru - Experienced User
Do you mean the Nighthawk App?
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
It should be RG 1.1.0.36.
Has your ISP updated the firmware on your CAX80?
How do I update the firmware on my CAX-series cable modem router or CBR-series cable Orbi router?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
