dapunz
Nov 23, 2022Follower
Can't access app CAX80
I've tried to access the app multiple times and it keeps bringing me back to the login screen.
Nov 24, 2022Guru - Experienced User
Is this the NH app? If so, what platform are you using?
If Apple, be sure WiFi Private IP address features.
Be sure the Apple device is on the Local Network and its enabled for the app as well.
What version of app are you using?
What mobile OS version are you using?
NH app has been seeing some problems lately.
