adev
May 18, 2015Aspirant
Can't access Genie settings
So this seems to have happened overnight, I'm not sure of the cause but it is very frustrating. I can not see or access any of the settings or values, yet the router is still working flawlessly. l...
rpoffen
Jul 08, 2015Virtuoso
hero1318 wrote: My Android 4.4.4 tablet updated automatically to Netgear Genie v2.4.8 tonight and now I can't log into the router (WNDR4300v2) on the tablet. I enter the password and click log in but the screen blinks and goes back to the same log-in screen.
My Windows 10 PC got updated to v2.4.12 tonight and it works. I can log in to the router with Netgear Genie using the exact same password on the PC.
The tablet connects to the router on 5 GHz band and seems to work fine, it's just that the Genie app doesn't work. I uninstalled and reinstalled it on the tablet with same result - can't log in.
Bummer! :mad:
FYI, it has been noted in these forums that running the Genie app on your PC can cause problems with the router. It is recommended to uninstall it from your PC.
