Filmman586
May 14, 2018Aspirant
Can't access Netgenie App
Hello,
I try to access my router through the netgenie app and I get a router timeout failure it asks for my password and times out. Please advise. I cannot access my Wifi Settings
michaelkenward
May 15, 2018Guru - Experienced User
Filmman586 wrote:
Hello,
I try to access my router through the netgenie app ...
Which one? Android? iPhone? Desktop (PC/MAC)?
Use a browser?
There is a manual for the R7300DST somewhere at the end of this link:
>>>>> R7300DST | Product | Support | NETGEAR <<<
See page 31.
What firmware version do you have on the R7300DST? A number is more useful than any "the latest" guesses. It may not be by the time people read this, and there can be newer versions, or "hot fixes", that do not show up in the browser interface.
Filmman586
May 15, 2018Aspirant
I can't access through either the PC or the iOS app. I can in a browser but not through any of the apps.
Firmware version: V1.0.0.62_1.0.21
- michaelkenwardMay 15, 2018Guru - Experienced User
Without explaining what you are doing and where it goes wrong, we will not get you much further.
For examples, what does "can't access" mean?
It rejects a password? Sits "thinking" but goes nowhere?
Is this local access, connected to your own wifi, or remote access going through an internet connection?
- Filmman586May 15, 2018Aspirant
When I access the app on my iphone and try to access my wifi, setting, traffic map, I get these scrrens. It work at one point on my PC and app, but now it doesnt. I'm not sure if it was after the most recent fiirmware update or one previous.
- Filmman586May 19, 2018Aspirant
Any help would be appreciated..
