mlandy
Aug 06, 2022Aspirant
Can't connect R6700V3 V1.0.4.122_10.0.95 to Nighthawk 2.19.0.2392 via android 11 phone
but access works thru browser with same p/w LOGIN TIMED OUT I tried rebooting phone, router, cable modem disconnected after this persists.
mlandy
Aug 08, 2022Aspirant
michael, thank you for responding. yes, that was the nighthawk version downloaded from google play store.
by cable modem i meant my isp modem, provided by t-mobile.
]the only way i know to update my firmware is through the web interface so its possibly outdated if i do not have a newer router.
(not prepared to buy a new one at this time - is that necessary to use the android app?)
michaelkenward
Aug 08, 2022Guru - Experienced User
What is it/ ISPs supply all manner of different modems and modem/routers.
Never the most reliable way to go about it.
There have been a couple of updates since your version.
Nighthawk R6700v3 | AC1750 Smart WiFi Router | NETGEAR Support
Then this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
No:
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
