jhoff909
Jun 22, 2021Apprentice
Can't connect to extender after setup
I setup the extender using the nighthawk app on my Android phone. Went OK. It automagically sets the extender wifi SSID to the same as my router. My router is a Netgear Orbi which has the 2.4 and ...
jhoff909
Jul 02, 2021Apprentice
How are you trying to log in to the extender? Can you take a screenshot of the page you are starting at and the result when you try to log in?
Do you know how, thru your router, to find out what the IP address of your extender is? If you can figure that out, you can put that IP address into your browser URL bar then you will get a login page for the extender.
Poet1369
Jul 02, 2021Aspirant
Thx for getting back to me, jhoff.
Try as I might, I can't even find the IP for my router. I work on a HP desktop. but also an iPhone7S. The app is on my phone, but can't download it to my PC. I'm totally baffled.
The extender IS working, but I can't log into it, even after a factory reset.
Also, When I try to log into the Admin page, it will not accept the default password(s).
There's just GOT to be an easier way.
As I read it now? The extender has creatd an unsecured network.
- Poet1369Jul 02, 2021Aspirant
I found my IP address, But when I type it into my browswer, It won't load.
Using the devices finder, the extender doesn't show up at all.
- jhoff909Jul 02, 2021Apprentice
This was the whole point of my initial post.... I wonder, is there any possibility to call Netgear support? What router do you have? I have a netgear Orbi and I was, from it's UI, able to find the IP address of my extender, go there and log in and manage it. In my case, I wanted to change the SSIDs as it was replacing another extender and it had different SSIDs that I had a bunch of devices (ok 4) already setup to connect to it in my garage. The phone apps, IMO are garbage. They don't give you the ability to configure or even see all of the settings.
Hi jhoff,
I'm on satellite from Xplorenet, so I have a modem & router from them.
I managed to find MY IP address, AND the router's as well. However, when i type in both adresses, they won't respond to the search. I have a call in to Xplorenet tech support, and am waiting for a call back.
I spent 6 hours yesterday trying to configure the extender, and 4 more today.
This 68 year old fart is getting frustrated.
Netgear offers support for a whole bunch of coin. Over $200 for 2 years, or $50 per incident. I'm on a frikkin pension, so not loaded by any means. It's why I reached out here.
