jhoff909
Jun 22, 2021Apprentice
Can't connect to extender after setup
I setup the extender using the nighthawk app on my Android phone. Went OK. It automagically sets the extender wifi SSID to the same as my router. My router is a Netgear Orbi which has the 2.4 and ...
jhoff909
Jul 02, 2021Apprentice
This was the whole point of my initial post.... I wonder, is there any possibility to call Netgear support? What router do you have? I have a netgear Orbi and I was, from it's UI, able to find the IP address of my extender, go there and log in and manage it. In my case, I wanted to change the SSIDs as it was replacing another extender and it had different SSIDs that I had a bunch of devices (ok 4) already setup to connect to it in my garage. The phone apps, IMO are garbage. They don't give you the ability to configure or even see all of the settings.
michaelkenward
Jul 02, 2021Guru - Experienced User
There is no phone support for Netgear. You do it via the support portal:
Contact Us | Support | NETGEAR
First you have to register your device to confirm that it is eligible for the 90-days free support. Start here:
MyNETGEAR | Product Registration
Start a case and, with luck, they will contact you.
After 90 days, Netgear farms paid support out to GearHead.
Or you can try to sort it out here. That costs you nothing.
jhoff909 wrote:
I have a netgear Orbi and I was....
Netgear makes a bunch of Orbi devices. They don't all work in exactly the same way. So knowing the model number – look at the label on the thing – can help people to help you.
You might also find more useful stuff over in the section where they pick over the entrails of Orbi devices.
You have posted your message in the section of this community given over to that stuff.
Hard to disagree with that. Seriously dumbed down to make these things easy for a novice to set up .
Experienced users go for the browser graphical user interface,
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
