southall
Aug 28, 2016Aspirant
Can't connect to Netgear Genie app using ios or ipad
I recently changed my wifi password and since then i cant access the genie app on my iphone, ipad or the mac desktop app. I can access it through the browser window but cant through the app. Ive de...
DexterJB
Aug 28, 2016NETGEAR Moderator
Hi southall,
1. Please make sure your device is connected to your router's wireless network when logging in through the Genie app.
2. Are you getting an error message? If yes, what is the error message?
3. What version on the Genie app do you have installed?
Dexter
Community Team
Lynnwood
Aug 30, 2016Aspirant
This is a known issue with currently released version NETGEAR Genie. I had exact same issue and contacted OpenDNS and they basically acknowledged that this has been happening for a while with Genie. I wish NETGEAR would stop wasting our time with your questions about what version we're running, etc. You KNOW the error message. Several posts have quoted it and the issue is with the currently released version of Genie. Just acknowledge the problem and tell us when they will release a version of Genie that works.
- DexterJBAug 31, 2016NETGEAR Moderator
Hi Lynnwood,
southall did not mention anything related to OpenDNS and/or Parental Controls since he is only unable to login through the app/program after changing the WiFi password according to his/her description. The information that we ask helps us isolate the issue and provide the best recommendation for other users as well.
Are you experiencing the same issue as southall? Please provide a description for us to assist you.
Dexter
Community Team
